This is what I propose. Let's see if the 905 will lock up on W5 using the HITS EMM provider.
The 4DTV provider is 4096 HITS is 4160. Can someone see in Options 6, 3, 1, Provider. Enter 4160 and see if it says correct signal found. It will be green if it stays red and says searching for signal a master reset may need to be done first. If that's the case if someone wants to tinker and see if it shows up that way. That will show the 4DTV will work with Comcasts SAC and should be a no brainer for Motorola. If someone does do a MR I wonder if the channel numbers would change to HITS lineup in theory they should. I wish I had a 905 to mess with.
BTW does anyone know how to force an manual EMM provider in the 920 or 922? I wonder if all you have to do is a MR and point at W5?
EDIT
I did some reading on the net and it said that if you do a soft reboot this clears the EMM provider then it should find whatever you point at so anyone with a 905 see if 4160 will lock on W5 if it don't show up first forget the MR idea.
EDIT
