I bought this for my "man cave" earlier in the summer but ended up not needing it. Paid $139.99 on Amazon, will sell for $125 shipped to your door. Here is their description. Still brand new, sealed in the box.
Recommend only to use for 4K 30Hz, if you aren't sure what this means.
gofanco 4x4 HDMI Matrix 4K 30Hz
Allows you to connect up to four HDMI source devices and independently distribute any source to any of the four HDMI displays. Easily switch between the four sources onto any of the four connected displays. Choose to have the same content on all displays or different content on each display! - Made in TaiwanCost Effective 4x4 HDMI Matrix
Features
- Supports HDMI 1.4 & HDCP 2.2
- Supports resolutions: Up to 4K @60Hz 4:2:0, 4K @30Hz, and 1080p 3D video
- Supports DTS-HD, Dolby TrueHD, 7.1ch digital audio and all other HDMI standard formats
- Smart EDID management allows for automatic facilitation of format control between source and display to ensure high quality video
- Firmware upgradeable for expanded compatibility through mini USB or RS-232
Excellent A/V Distribution Solution
HDMI signal routing in environments where multiple AV sources must be shared in 4 different zone or displays, to reduce the installed equipment clutter and to reduce the costs involved with multiple, redundant devices.Note about resolution
If you plan to use for 4K 60Hz, it MUST be in 4:2:0 chroma subsampling (not 4:4:4 or 4:2:2).Recommend only to use for 4K 30Hz, if you aren't sure what this means.
Multiple Switching Options
- Front Panel Push Buttons
- Local IR Remote Control
- RS-232 Control
Friendly Reminders
| Specifications
| Compatible Devices
| What's in the Package
