Anyone know why MCE doesn't have the VOOM lineup
Flambe
66
I would love to use my MCE box to record shows from VOOM (I know it gets the signal, and I'm ok w/ not getting full HD recordings), but MCE doesn't seem to have the VOOM channel line up!
Anyone know why? Is this a licensing thing?
-F
MCE = Microsoft Windows XP Media Center Edition. I just checked mine and it doesnt list Voom either.
It's there now
VOOM is showing up in my list of satellite carriers now (actually, has for a week or so). So, Windows Media Center is happily recording shows now! (well, those that the content providers allow you to - some shows/networks are DRM'd (like HBO)).
-F
Wait a minute. Are you running through a STB and then into the computer, or directly from a a split coax cable?
Are you then watching from your monitor, or do you have a system to get the recorded material on your main TV?
I happily record downrezzed HD to my Panny E85H then burn to DVD. I have burned over 150 DVD movies from Voom so far without a glitch.
Voom with XP MCE 2005?
If anyone could enlighten me as to how this works... I'm considering getting a MCE computer, since supposedly the 2005 edition supports HDTV. However, I'm wondering how to hook up the Voom receiver to it. Would I be able to record HD signals from the Voom box, or just off-air signals? And would I be able to record SD from the Voom box? Confused...
-TR
No, you cant record HD signals from the Voom box. MCE2005 only supports OTA HD.
I didn't hear an answer to this question yet.
Are you running the signal through your Voom STB via coax, s-video OR are you running the signal directly into the MCE using the RG6 cable from the dish?
Thanks!
pederb said:
If you had a capture card with component or RGB/VGA in you should be able to record HD right
Yeah, except there are none, Hollywood is too paranoid. :mad: :no
Just to clarify, I am recording the SD feed via MCE. no HD recording for me. Of course SD off of VOOM is still better than the old cable signal I used to receive!
I am looking forward to ah HD-capable DVR (it will immediately replace my MCE solution).
-F
Voom and replay.
Why does a DVR have to be a Voom product?
