I ordered a new SG-2100 motor and its different than the others I"ve had. It has separate east west buttons on it. The older ones had one button, press and hold once to move west, press twice and hold to move east.
The problem I'm having is that the motor came out of the box ,about 4 degrees off zero, although you can reset the motor, the reset doesn't zero the motor, just re-loads the satellite list to factory. I e-mailed the vendor and he said he's sold a few hundred of them without problems. He said the reference point is just that, a reference and it won't matter, usals will work fine. It seems to work ok, although I'm have trouble getting the ends of the arc aligned, but that may be alignment related. Its kind of weird in that I mount the motor on the mast, point it south but the dish is off south by 4 degrees or so. I can't use the lnbf arm to line up the dish with a compass any more, just have to look at the motor from the back of the dish and try to get it close. Four degrees doesn't sound like much but it is visually noticeable. Has anyone got one of these beasts and is it off zero or did I get the only one like that?
