Has anyone noticed occasional audio stuttering or skipping? On my HR20 thru HDMI I've had this happen every once in a while. Doesn't seem to be on one particular channel and only happens for like a second.
I've also noticed when its raining, even a light rain, the HD channels will break up but when I turned to the SD channels there was no breakup at all. I was on the phone with a tech the other day and he said the HD signal might not be as strong right now as the SD signal but will eventually become stronger as they work the kinks out. I checked signal strengths when the weather is ok and they all look decent, mid 80's to 90's.
Anyone else having these issues with they're HR20? Could it just be a bad multi-switch or are these occasional glitches more of a signal issue? A tech is coming out tomorrow, I thought of having him swap HDMI cables on the HR20 but not sure if that's the problem.
I've also been having an issue with an H20 lately where it will say there's a problem with the multi-switch or receiver. You turn to a channel you've been getting all along and it will say you're not subscribed to it. Tried a couple resets but didn't help. Bad receiver or multi-switch?
