I've noticed this new model release that has caught my attention, it appears quite appealing and would like to know if anybody has purchased one yet and what you have to say about it. It's currently priced under $200 and is designed for use with the Pansat DVB-S2 Plus module. I noticed that it mentions a optional S3 tuner, what is this new S3 tuner? Is it referring to the 4:2:2 signals?
Pansat TC-1000 HD (PVR) FTA REPLACES 9200 250 3500 150
Features
•ATSC High Definition(Single MP@HL,MPEG-1,MPEG-2
•External SATA PVR(Format function ,Recording,Playback,Timer Recording)
•USB 1.1 Host Interface(Front ) - Firmware Update
•High Definition Video Output :HDMI and Component(Y,Pb,Pr)
•Audio decoding :MPEG-1,MPEG-2,MUSICAM,Dolby AC-3
•54 ~ 866(VHF low ,VHF high, UHF band) MHz input Frequency(IF Loop throughout)
•Variable Input Symbol Rate (1 ~ 45Msps)
•User selectable output resolution
•Video output resolution :480p,720p,1080i
•Support EPG
•1000 Channels TV & Radio program
•Timer setting supports automatic Turn-ON and OFF daily
•Fast Channel change
•Multi language OSD
•Powerful Channel Editing Function(Favorite,Move,Find,Sort,Delete,Skip,Lock,Edit,Create)
•Digital S/PDIF (Digital Audio or Dolby AC3 stream out)
•Automatic PAL/NTSC Conversion
•5 Favorite List & Unlimited Programs per each
•PIG (Picture In Graphic)
•Channel Editing Function : Sorting(Alphabetic,Parental Lock),Move,Delete,Favorite Edit,Parental Lock,
Channel rename,Channel Skip
•Software Upgrade via USB
•RTC (Real Time Clock)
•UHF Ready (U-50 kit Optional)
•DVB-S3 Ready(S3 Tuner Kit optional)
ATSC Tuner
•1RF Input Connector : F-type,IEC169-24
•1RF output(loop through) : F-type,Zero power Loop-through output
•Frequency Range : NTSC all band,54MHz to 866MHz
•ATSC A/53 compliant 8/16 VSB and MMDS 2/4/8/16 VSB
•ITU-T J.83 Annex B,C compliant 64/25QAM
•Integrated de-interleaver RAM for all Modes
•Relative Low power consumption
MPEG transport Stream A/V Decoding
•Demultiplex : MPEG-2 ISO/IEC 13818-1(MPEG-2 system)
•Input stream : Max. 90Mbit/s
•Aspect Ratio : 4:3(default), 16:9 letterbox
•Video Decoding : ISO/IEC 13818-2(MPEG2 vidoe) MP@HL
•Audio Decoding : ISO/IEC13818-3(MPEG2 audio/MUSICAM) ,Dolby AC-3
•Video Ouput : HDMI,Component(YPbPr),CVBS
•Audio Mode : Single Channel /Dual Channel, Stereo, Joint Stereo
•Audio Sampling Frequency : 16/22,05/24/32/41,1/48 KHz
Microprocessor & Memories
•Main Processor : ARM926
•CPU Clock : 280MIPS
•Flash Memory : 4 Mbyte
•DDR SDRAM : 64 Mbyte
•EEPROM : 64 Kbit
A/V output
•Component Jack : Y, Pb ,Pr
•Video RCA : 1 output
•Audio RCA : 2 output(Reft,Right)
•Digital Audio : 1 optical output S/PDIF
Front Panel
•Display : 4Digits LED
•8 keys : Power,Channel Down/Up, Volume up/down,Menu,Exit,OK
•USB : USB2.0 1 Host
Data port
•Connector : 9 Pin D-Sub Type
•Protocol : RS232 Asynchronous
•Data Rate : Max. 19.2Kbps
Rear Panel
•Tuner : 1 input with loop through 1 Loopthrough output
•UHF : Stereo Jack
•6RCA : Video, Audio L, Audio R, YPbPr
•HDMI : Type A
•S/PDIF : Optical
•eSATA : External HDD module
•Data Port : RS 232
•Power Switch : Rocker Type
•Power cord : Fixed type on the body
Remote Control
•Type : IR RCU
•Battery : 2x1.5V AAA Type
Power Supply
•Input Voltage : AC 90-250V, 50/60Hz
•Power Consumption : Max. 30 Watts
•Type : SMPS(Switching mode power supply)
Physical Specification
•Dimension (WxDxH) : 280x210x60
•Weight : 1.8Kg
•Accessaries : RCU,Battery,User manual
Features
•Support EPG
•Multi language OSD
ATSC Tuner
•EEPROM : 64 Kbit
A/V output
Front Panel
Data port
Rear Panel
•UHF : Stereo Jack
•HDMI : Type A
•S/PDIF : Optical
•Data Port : RS 232
Remote Control
•Type : IR RCU
Power Supply
•Weight : 1.8Kg
