I have to add a really stupid question to this thread. On my dish, I'm getting strong (95+) signals from 101 and 110, but a weaker signal from the 119 (around 75). Normally this isn't a problem, but on rainy days like today, the 119 drops off considerably (less than 30), which is a problem.
I have two basic questions:
1) If I'm looking at the dish's line of site (i'm in maryland), I know that the center is aimed at the 110. Is the 101 sat located to the left or right as I look up to the sky? Seems dumb, but there is a possible tree problem on the left-hand side, with nothing potentially blocking the right-hand side. Since I assumed that the 101 is to the left, I figured the tree wasn't an issue since my signal is 95+ for that sat. However, I'm 2nd guessing myself because of the 119 signal. Either I need to realign the dish, or the 119 sat is to the left of center, and the tree is an issue.
2) If I need to realign, what is the best way in terms of the order to adjust things? I realize that should not just loosen all screws and start moving the dish all over the place. My process so far is to start with one adjustment and get the signals as strong as possible before moving on to the next one. The order I've done so far is azimuth, tilt, skew. Maybe this is the best I can get the signals, but I figured someone might have some suggestions for further tweaking. Is it possible to get all 3 sats at signals of over 90%? The post is mounted on my concrete foundation, and is very near exactly plumb...slightly off, but more than 50% of the leveling bubble is within the target circle.
