Stacy A said:
I beg to differ. I live 120 Miles from Dallas and I have four of the digital stations locked into my 6000. I typically can only receive them after dark, but I do, in fact, pick them up.
Well, most "mortals" want to be able to pick up stations in the DAYTIME as well, which this guy seems to fall into this catagory. Most people do NOT go to this trouble to be able to watch something only a few hours a day.
While I am sure there are people that DO this that are REALLY into TV, as I have done in my younger days, it's different now in the digital world. Obviously in the analog world, you can get something most times, even if the picture quality can vary much - in the digital world, you either get it or NOT! And in your case with trying to pull something in 100 miles away that "only comes in after dark", it's not worth the hassle to me. Especially in my case, since I now have access to 5 markets of local TV from across the country clearly through dishes, (not to mention the 4 HD stations from NY) it's not worth the hassle to me anymore to go through this via antenna.
I use a channelmaster deep fringe UHF only coupled with a RS 30db pre-amp. My local channel towers are approximatley 65 miles northeast of me (Shreveport) and 45-50 miles west (Tyler/Longview). Using the high gain amp caused no loss of any of the closer channels, analog or digital. The one most subject to cross modulation (closest to me and highest in power transmission) did not go away.
Uh, well - you just proved my point. Not sure if you realize this, but "45-50 miles" away is quite a bit different than 30 miles away, at least as far as overload to a pre-amp.
It's just that according to what you are saying, I should have lost channels when I installed the system I have. And that was not the case at all.
In YOUR case, I am NOT saying that at all - read my answer above.
It did exactly what I wanted it to do: pick up Dallas OTA digitals and the digital PBS out of Shreveport which runs at a low power. I used to only be able to pick it up on nights when the skip was good. Now I can pick it up every night. I did lose some signal strength on my CBS digital out of Shreveport. It dropped from 90%+ to mid-80%. That was not a big deal.
That's good - BUT, you are in a different situation.
I am NOT saying that it is NOT possible for the orginal poster to get what he wants, but he's gonna have to work at it, as well as spend some $$$ to accomplish this, just as Dr. Al said above.
(who obviously has worked with this stuff for sometime as well)
And I guess a couple things I'd like to add back to the original poster...
-Also another point I forgot to add - you are dealing with an E* 811 receiver, which I read around here is not the best at dealing with "non-perfect" off-air signals. If you REALLY want some of these distant stations, you might want to try a better HD receiver. (to be blunt about it)
-You now have 2 people here giving you different solutions, but who are saying that you have the SAME problem of local overload, but you keep arguing about it. Have you thought about actually taking some of our advice - my solution would be the cheaper one & would be the easiest/cheapest to fix.
Also understand one thing - I DO NOT GUARANTEE 100% THIS WILL SOLVE YOUR PROBLEM, since I don't have the advantage of seeing your setup firsthand! But again, my experience tells me this would be the first place to start. You have to get into your mindset that BIGGER (ie: high-gain) IS NOT ALWAYS BETTER!
Also, have you given any thought to contacting a local antenna dealer for some help. (who will probably tell you the same things we have) It basically comes down to - HOW badly DO you want those distant stations?
