Another multiswitch questions
seadog99
6
I have a triple LNB elliptical dish(4 outputs) running to a 5x8 switch. 4 outputs run into my living room and one runs upstairs.The other 3 are empty. Rather than running more lines into the living room from the 5x8 switch ,can I plug the existing 4 living room lines into another 4x8 switch to add 2 more receivers? I tried an old 3x4 switch with plugging 2 out of the 4 lines into it and I only got odd transponders I believe.
Thank You
If you were to get a cascadable switch, it should actually work, assuming that you really have 4 separate lines from the first switch.
Actually, the 3x4 switch would work as well, provided that you did NOT need anything from the 110/119 slots on those same receivers on the 2nd switch - if you don't need locals/spanish or HD on those added receivers, it will work fine as well.
so when you say "really have 4 seperate lines" what would qualify them as not seperate. Like i mentioned they are 4 of 8 from the 5x8 switch.
Also what switches are cascadable. Does the existing 5x8 need to be cascadable as well because i am not even sure what brand it is? Also which switches would work so I could get HD onto the added receivers
thanks again, this site is very helpful!
sorry, just checking... :cool:
Is your current oval dish a newer one, with the imbedded switch & LNB? If so, then your current switch MUST be cascadable, otherwise it would not be working properly. You could just get another one just like it, or go online & search the many sites selling 4/5 x 8 switches & get one that specifies it's cascadable. (the majority of the them nowadays are anyway) If you are wanting HD, you must use another 5x8 - a 3 in switch will NOT work right.
Here's a whole page of some:
http://www.sadoun.com/Sat/Order/Switches/DirecTV-switches.htm
(don't mess with this one; it's only needed for markets w/locals on 72.5 or ethnic on 95)
http://www.sadoun.com/Sat/Products/Zinwell/SAM6802.jpg
Is your current oval dish a newer one, with the imbedded switch & LNB? cascadable.
Yes it is a newer one
So just to confirm the only way for me to do this(and get HD) is to run my existing 4 living room lines(out of 8 from the first 5/8) into another cascadable 5x8 switch. Nothing smaller will do the trick? If I don't want HD a 3xN switch should do the trick? Do either of these need to be powered/amplified etc?
Is there a simple reason why my 3x4 switch will not do the trick? I wonder if this is because it is older and probably not cascadable? or probably something totally different?
thanks so much again, you are a super helpful person ;)
seadog99 said:
So just to cofirm the only way for me to do this is run my existing 4 living room lines into a cascadable 4/5x8 switch. Nothing smaller will do the trick?
Well, think about it for a sec - you are eating up ALL 4 lines going into your living room, with the purpose of getting MORE than 4 lines in the first place - the ONLY switch smaller than 5x8 is 4x4, which obviously defeats the purpose of another switch in the first place, right? ;) ;)
Is there a simple reason why my 2/3x4 switch will not do the trick?
Yes, because it is NOT meant to work with multiple dish slots - those are ONLY meant to receive signals from 1 slot. (typically the 101 slot where the core prog is)
How about 3x4? thats 2 of my 4 lines in and 4 lines out which nets me 2 lines more? Even though it won't work with HD right?
It will ONLY give you the 101 slot; it will NOT give you ANY prog from 110/119, period (and you will NOT get most of the HD channels, which is what you said you needed) - that is ALL they are designed for. But, if you are satisfied with ONLY 101 for ALL 4 of those added lines, then yes, it will work fine.
Here's a cheap 5x8 switch - I ordered a couple of these for myself today:
http://www.consumerdepot.com/products.asp?id=DX-MS101
Also, since we do NOT know where you live, if your locals are on 119, you would NOT get them if they are on 119, if you were to use a 3x4 switch. ;)
wow thats a hell of a deal. I'll get this one! Thanks again
All lines are Signal (A)
paying a fee of US5.00 for each receiver
