Why would you want a new dish?
So I can go from 2 dish set up to just 1.
Sure can . Many of us had that very configuration for a number of years; DISH 500 + side sat for 61.5. As for your locals you can plug in your address into DISH's locals address broker and it should tell you what is available and what sat it comes off of. Another thing you can do is take the biggest city that DISH carries ,that is closest to your area , within 100 miles and use that city to "move" to for hd locals.
Thanks MikeD. I'm assuming that with the Legacy setup I will use an SW64 ( 6 in, 4 out)? I could also use 5 high frequency splitters and 2 SW64's to get 8 out?
If I switch my existing dish to a Dish 500 and use DP lnb's, how does this affect the number of RG6 cables I will need to bring down from the dish(s) and the type of switches I will need to get 8 outputs I will need to run 6 (or more) tuners in the house.
I have no experience with Dishpro equipment.
THanks,
grover
It would be cheaper and easier to go to Dishpro equipment, especially with dual tuner receivers. How many receivers are you going to have?
Hey Digi... Looking at TheList, it seems as if eastern arc has a number of HD locals on Conus beams. Do you think it will stay that way?
As long as you have all mpeg4 ViP receivers, you can install a 1000.4 and make no calls or do anything else other than run the Check Switch after installation. I assume you likely have a D500 pointing at 110 and 119 and another at 61.5. If I were you, I'd keep this setup for the time being. The western arc has the newest satellites with a new 119 going up soon. The eastern arc won't be all new for a couple of years or so.
You are correct, but the location of the two dishes are quite a distance apart, if they were right next to each other I would'nt care, but due to trees can't be. So would it be possible to move the 110/119 dish to the same location as the 61.5 and use it for the 72/77 satellites?
