larsh74 said:How many dual tuner receivers can be connected to a DPP 44 at one time? It seems to me that 4 receivers could be connected if each one had a seperator. Any help will be greatly appreciated.
larsh74 said:I did not know that the LNBs must also be DPP. Currently there is a SuperDish
(119 and 110) and a Dish 300 (61.5) at the customer's home. We want to add a 622 and was under the impression that this could be done using a single cable with a seperator and a DPP 44 switch. Is this not correct?
WRONG......Clancy said:It will not accept a feed from a DishPro Twin LNBF.
n0qcu said:WRONG......
What you can't do is use the DPP Twin to feed a DP34 switch.
The ONLY[/] DPP LNB is the twin.
Any DishPro LNB (single, dual, twin or quad) can be used with the DPP 44 switch.
With that Avatar, it could be hares, cats, dogs, frankly anything you're pointing at...!webbydude said:...Sorry...LOL...am I splitting hairs?
