I need to use the pass-through Antenna/Cable coax input to TV1 to bring my DVD signal upstairs using the same coax wire as using for TV1. (It had been TV2 but that does not pass-through the cable/antenna coax input.) I use my DVR625 in single mode anyway. This way I can watch the DVR upstairs and when I turn it off I can watch the pass through signal, in my case the DVD without running more coax.
This works...but there is an annoying faint transluscent Dish logo that runs from left to right across the picture continuously while I am trying to watch the DVD. At first you barely see it but once you do it is terrible.
Has anyone else seen this or know a solution.
TIA,
Telstar_2112
TIA,
Telstar_2112
