Anchorage, Alaska & Galaxy 25
Sadoun
2,320
Columbus, OHIO
Anyone in Anchorage, Alaska can report back on the size of dish they are using to receive KU signal from Galaxy 25 (97W)?
What receiver & LNBF are used?
Does the signal strength fluctuate or pretty steady?
What LNBF skew are used?
Hi Alaska guys. Any experience with G25 at Anchorage? I have potential to sell 5 systems there to a customer, but I want to verify the dish size needed. Your help is appreciated.
I am perfectly willing to be flown up there to do field research, if needed ;)
A 1.2M dish with a skew of approx. 25 degrees will be suitable for Anchorage, AK. We ship the standard linear LNBF for Anchorage, but the Invacoms work better if further North.
The wind loads can be very extreme, so we would not suggest a lighter duty dish.
The elevation is quite low, about 9 to 11 degrees. Anywhere in Eagle River and Wasilla is good. But when you get closer to the mountain range like Palmer, then the mountains block Galaxy 25.
Another unknown is what the EIRP level will be on the replacement satellite Galaxy 19, which is scheduled to be put into the 97 West position in a few short months, allowing Galaxy 25 to move to other duties (probably 93 West).
A 1.2 meter is a good conservative antenna for the present time, and I doubt that even if a significant improvement is made in signal levels, that anything smaller than 90 cm should even be considered. And as a previous poster said---elevation angles are quite low in south-central Alaska, in the single digits---meaning that many locations will have problems clearing terrain to the southeast. Only the western and northern areas of the main part of Anchorage will have a clear shot over the Chugach Mountains, and then in most cases it will take a rooftop installation. Any cheaply made antenna will not last a season in this community, due to multiple yearly events of Chinook winds that are often of hurricane intensity. If you need to deal with 1.2 meter antennas, it would be best to make a package deal from a company such as Satellite Alaska in Anchorage, who would be happy to sell wholesale to a company such as Sadoun---they bring in antennas by the container-load into Anchorage. Check the freight costs of bringing in five units even by the cheapest air freight company, and you will find that it is not economical.
Mike & All
Thanks for the feedback and suggestions. I thought a 1.5 or 1.8m offset dish would have been required due to the low signal strength and low dish elevation. If 1.2m works fine, then that will do it.
I will check with Satellite Alaska on dishes.
would be cheaper for me to go to Ohio and grab some then sell them to folks on the way back :D
Well, bummer. The mountains will block the signal for the customer's location.
BTW, Checked with Sat. Alaska, they have plenty of dishes. It seems like a one man operation. He charges $450-$650 for installation of a dish. I don't blame him for working outside at 13 F today.
52nd Annual Shelby Hamfest
KHIZ Check
