I am working on an antenna setup and switching a few things around. I have a couple old Radio shack antenna amplifiers. 15-1113b. 20 db inline amps. These are old amps. Strange both act the same way. I am getting a signal strength on the TV, on several channels about 50%. (TV signal strength meter) When I connect the amplifier the signal strength drops very low. The more I decrease the amp, the more the signal increases. Both amps do the same. With the amps turned all the way up I get a TV signal strength 10% and with the amps turned all the way down I have about 40-45%. A slight bit less than without the amp. Locals get weaker, distant stations drop to nothing. (If I unplug the amp I get pretty much no signal)
Are these amps bad? I do not think they are over driving. Stations are weak to fair to begin with.
I am also using an amplified splitter for 4 TVs. It does the same whether before the splitter or if I bypass the splitter and go straight from the antenna to one TV.
