After a long hiatus from the hobby (15 years), I have purchased a new Amiko Mini 4k uhd s2x. These comments apply to the 4k unit only as i dont have the earlier model. Here are my impressions.
1. Channel List and Satellite memory: Insufficient
I have maxed out the channel and satellite memory with FTA ku entries only (no scrambled). My ku 1 meter H2H setup covers 18 - 139 west. Even though the most Eastern and western sats are present on the channel file, there appears to be a bug - in the f/w that prevents the last satellite (139 west or anything below 30 west) from appearing on the list or from showing up when you press the sat or menu buttons in satellite installation to do scans. (maybe I'm missing something here...) (update: I see now it only displays satellites that have active video, so it should not say "all satelites, confusing...) For folks having C/ku setups with lots of arc visibilty these satellite and channel limitations will be severe on this receiver as they wl run out of channel memory.
2. Buggy and unreliable blind scan. Sometimes it just hangs on a scan of a sat with lots of transponders (as I'm writing this, it just hung on 81% of 121west scan). Although it appears to be improved in the last f/w (dated end of June 2023 ver 1.0.56), the tuner also still appears to go off to lala land after completing blind scans way to often, and even though pressing menu to back out and save, the video doesn't always display properly in newly found channels until turning the unit on and off or doing a hard reset. Subsequent blind scans on other sats may also not find anything until the unit is reset. My workaround is to start the blind scan from a channel that is already active on that sat, BUT thats useless on scanning new sats without active transponders found or known yet.
3. The channel editor (Ali editor) is cr*p software (and I'm being kind...) when compared to other proper channel editing software such as the old ChanneMaster, or even MediaStudio or Clarke-tech Editors which unfortunately may not be completely compatible with the type of .abs file that this receiver produces (i get invalid file or a corrupted channel list display when loading the Amiko .abs into these editors although the satellite and transponder listing from the same file are fine though...). Amiko and vendors would have less support issues if a proper editor with the usual options such as column, channel, pid, satellite sorting, etc... was made available or Amiko should debug why their .abs channel listings are corrupted when displayed in standard editing software other than Ali editor. Sadly, the software of the 1990s - like ChannelMaster, or Rod Hewitts DvbEdit & TSreader have spoiled me and are far superior to this Ali editor...
This receiver has a lot of positive aspects but if some of these issues stand unaddressed it will be frustrating for less experienced users.
