KU-Band is much different than C-Band. All KU-FSS sats have the same bandwidth, but the configuration of the bandwidth varies with some using 24TPs, 32TPs, 16TPs, and different combinations of bandwiths for TPs.
With so much misinformation floating around, here are the stats of AMC-6 at 72w.
Launched: Oct.22, 2000
Design Life: 15 years
Upload Bandwidth: 14000MHz-14500MHz (500MHz)
Download Bandwidth: 11700MHz-12200MHz (500MHz)
Available Bandwidth: 864MHz (432-Vertical/432-Horizontal)
Beacon Frequencies: 11702(V)MHz 12198(H)MHz
Transponder Output: 110watts
Transponder Configuration:
(1) 24 TPs at 36MHz (864MHz)
(2) 16 TPs at 36MHz (576MHz) and 4 TPs at 72MHz (288MHz) (864MHz total)
(864MHz is nearly 3 times and 576MHz is nearly double the bandwith available on Rainbow 1's 13 TPs)
Coverage Area:
CONUS; Mexico; Caribbean; Canada (southern); Central America; Bermuda; Alaska (panhandle, south of Juneau 10 ele)
ERIP & Typical Dishsize Needed (US):
Typical ERIP 48dB, 75cm/30in
Alaska (panhandle, south of Juneau 10 ele): 52dB, 50cm/20in
Oregon: 52dB, 50cm/20in
Ohio, West Virginia, Pennsylvania (western): 51dB, 55cm/22in
Texas (northeast): 51dB, 55cm/22in
Texas (remaining areas), New Mexico: 50dB, 60cm/25in
MI, IN, VA, MD, NC, PA(east), NY(west): 50dB, 60cm/25in
Great Plains: 48dB, 75cm/30in
All other areas: 49dB, 60cm/25in
Coverage Area:
