amc 16
danristheman
3,146
1,142
85w
Is amc-16 still broadcasting reason is this is my true south satellite and i want to put a motor on my dish and line it up with this satellite. What do you do if you can't get your true satellite? What else can you do?
Dan Rose
There is a thread in this, if not a FAQ
Basically, you tell the receiver to go to a satellite nearby your TS
The motor swings the dish over a few degrees
You set elevation and azimuth to get this alternate bird
With luck and care, you will be on the arc
Yes, I left out some critical steps, so see the discussion by SatelliteAV and others for the long version. ;)
There is a test card at 12195H 3978 on AMC16, if you are working on your dish. Usually it is on all day during the week, color bars and tone.
Ready to take the plunge!
i can't believe the signal quality with this 1.2 and k band lnb.
