OK, each day I get more stupid after failing to get a signal down here in Costa Rica.
Now, I am confused and do not know if I am using the inclinometer right, please help me.
1) First, Costa Rica, Latitud 10 N, Long 82.15. I should set my elevation on my 10 feet dish to 78 according to those values to get AMC 3 at 87. CORRECT?
2) Now, I am confused on how I am using the inclinometer. It looks like this:
|________________________90 (longest part)
Now, on the elevation bar behind the dish, I was setting the inclinometer using the smallest side to set to 78 degrees. The dish is almost pointing all the way up to the sky, I pretty much used all the inclination screw all the way up. Again, my dish is almot resting horizontally on the pole, the LNB is facing almost all the way to the sky. That should be correct rigth? the lnb for a 78 degree elevation should be pointing like that.
