As already mentioned, there are many factors that will effect the reception of the signals you are trying to receive. I have many stations in the 70mi to 80mi range that I get great reception from, and some in the 60mi range that I can not get. Now most of them are across water so that helps greatly, but I sporatically can receive one from 120mi. In my situation I use a tower with a 8 bay bowtie UHF antenna and a Channel Master pre-amplifer. (CM7775) I require the tower to get above the trees in my area for I have a good (but not totally clear) view towards the transmitting stations. In my situation, height makes an extreme difference. I have a rotor to peak the antenna direction to the station I am receiving, and most I find are very directional. A few degrees of the rotor can make the difference of a great signal or one that is always breaking up, or not coming in at all. Before using the CM7775, I was using an old Radio Shack pre-amplifer and could not get reliable reception from any stations. The very low noise preamplifer worked exceptionally well for me. To get an even lower noise preamplier, the price rises to 4 or 5 times the price of the CM7775, so that was not an option for me. I currently have a 30ft tower, but would like to put up a 70ft to 80ft tower, as I have hills in my area that prevent the reception of the stations 65mi from me. The transmitting stations power and direction can also make a big difference. Some stations put out a directional signal, so a waeker directional signal may travel farther than a more powerful non-directional signal. The height of the transmitting antenna and terrain of the are are other factors.
At 73mi away, if you do get reception, it probably will be sporatic. The best thing to do first, is to check any local tv antenna tower shops to see if what you are trying to receive can be done, and to see what they recomend. 73mi may be just to far for reliable reception in your area.
