After being a 10 year Dish Network user, helping out a half dozen friends and family, I've finally run into an aiming problem I just can't get around. It's in a back yard that does have a fair amount of trees and such, but I had done a pole mounting of a Dish 500 with two SW21's feeding two receivers in the house. It had been working since late last summer just fine. After a storm had messed up the signal a bit, we tried re-aiming the dish and just CAN'T get satellite 119 back again. The pole isn't perfectly level, so I'm working on a bit of guess work. However, since it had been working previously just fine, with both 110 and 119 coming in great, it's odd that it would suddenly develop issues getting 119 tuning. I can get 60% or so signal on transponders 5 & 7 which show as spotbeams. But I get nothing on any other transponders for 119. And it happened after all the trees had their leafs and such, so I don't think it's due to leaf growth. Are a couple of the spotbeams simply stronger than the rest of the transponders and that's why I can get them? I've tried switching all the cables, switches and LNB's between each other, but I still get the same results to both receivers. Could the skew angle be something that could help with just a partial couple transponders on 119 when 110 is coming in so perfectly? The skew tends to be the thing that makes the Dish 500's tougher without precise levels to work with. I don't know, I guess I'm hunting for any little tips and tricks in such a situation. I know the description's vague... ;-)
