ADTH IR6600 receiver
fred11119
tenn
Hello everyone,
I am new and need some help from you.
I have a ADTH IR6600 and try to get some FTA from Gal 3C.
Floowing the instruction, connection and dish setup were done (I got the Sat. & transporter's data from this site).
Since there is no blind scan func., I did the scan by manual. but got no singals at all. Can everyone give me some suggections?
My dish size is 30" and LNB is SSF-LNBF
Thanks!
If this is the new receiver within the two or three years period, you have no luck to modify anything from this model. AS you will only able to watch Satmex 6 signal.
I thought i read where you could manually add tp's with the remote for the ADTH IR6600 & 8600
if you entered that transponder into the box along with the polarity & SR then maybe the dish isn't set properly or the lnb isn't setup correctly .
the lnb you listed above i've never heard of. Does it have a information plate / sticker ? that has the LO on it? or is it a FSS lnbf ? a FSS lnbf is a stacked LNBF.
FSS is not necessarily stacked, it means Fixed Service Satellite (as opposed to DBS, Direct Broadcast Satellite). The FSS LNB on a Superdish is stacked. The linear LNB is stamped 'FSS' so it is not confused with the circular 'DBS' stamped LNB on the same dish. Having said that, I don't recall ever seeing 'FSS' actually stamped on any other linear LNB(F)s...
[ame="http://en.wikipedia.org/wiki/Fixed_Service_Satellite"]Fixed Service Satellite - Wikipedia, the free encyclopedia[/ame]
New Bie need help
DVBViewer and dvbworld 2104 help
