Adding receiver to my setup. Help needed
uranus
15
I have four sat system(110,119,129 and 61.5) connected to two receivers( one dual tuner HD and one single HD tuner). The sats are connected to dp44 multiswitch. I have an old receiver(legacy 3700) from my previous house which I want to reactivate. DO I need a dishpro adapter for it to work?. If yes where exactly do I need to connect. Can someone explain the connection tree to me. The new receivers are kinda complicated for my old folks.
Just like any other receiver. Run a coax from the DPP44 to the 3700 and screw it in the back. The big problem for you is how old is the software on the 3700, hopefully it will take necessary software updates. You could try calling tech support to see how out of date your software is and if it is updatable.
Adding 61.5 to a Dish1000??
Sending component video from 622 over cat 5
