AMIKO Adding New Transponder to A3
chc59
95
15
Dalton, Ohio
How do you add a new transponder manually to the A3? All I've seen is a SCAN of the transponders listed in the list for that Sat. D/L the transponder list and add it using the Spark 2 Editor? Then how do you scan just one transponder?There must be a way to scan one transponder
Joe
  1. Go to advanced install then of course choose tuner 1 as there is only the one tuner installed.
  2. Then move up/down and highlight the satellite you wish to modify.
  3. Next look at the very top of the screen you will see TP List -- Sat List -- Edit Satellite- Using your double arrowed left and right keys on remote move to TP List.
  4. At the bottom of screen you will see the color blocks, press the green key on the remote to "add a Transponder".
  5. Enter the required Transponder info and then press ok on remote to save.
  6. With that transponder highlighted press the red button on the remote to scan only that one transponder.
You will also see from there I think how to edit transponders, delete them, etc.
Hope this helps, and gets you in the right direction. :)
Reactions: dougruss
Fantastic. Thank you much. Kept missing that. Always cusored to the right to "Edit Satellite". Knew there had to be a way.
Joe
Reactions: KE4EST
AZBOX Premium HD crashes on upgrade
AMIKO What Number Goes into Motor "Position" using ASC1
