does anyone know if you can add dishpro lnb (110,119) to dish 1000 external in and receive 110, 119,61.5,72,&77 . I am adding 625 sd receiver in my garage to my present setup (722 in living room)
NO IT WILL NOT WORK The Eastern Arc (61.5/72.7 77) uses a 1000.4 dish and requires MPEG4 capable receivers. The 625 is a MPEG2 receiver so it won't work on Eastern Arc. The dish 500 uses a Twin LNB that has a built in switch which won't operate when connected to the 1000.4 so it can't switch from119 to 110.thanks for quick rreply, I meant 625 rx. still unclear... will both 110 and 119 come thru
