Adding a PVR721 to my Dishpro system
bd102
I already have a Dishpro system with two recievers in use --Models 301,
I purchased a PVR721, what is the easiest way to install it?, I want to
ADD it to the system and move one of the two 301's to a different room.
Do I need a DP34 switch? or do I need to run two more cables from the
dish?
I would say the easiest would be to get a DPP44 with a seperator, but that won't be the cheapest. That way you only need 1 line of coax run to each room.
If you have no problem running two lines to the 721, then the DP34 would be fairly inexpensive and easy.
You may also have extra outputs on your LNB, but can't tell from your message. That could be the absolute cheapest as all you pay for is cabling, but depending on your dish setup, it probably won't be the easiest.
Can I record a PPV
What to include with leased 811 return (cables)?
