Adding a manual channel.
iBoston
2,635
2,190
North Central
Where is a good source location to find the specs you need to add a manual channel.
Give you an example, i can find the Video Type and Video channel, And audio channel.
What i cannot find in many places is the audio type and the PCR PID? What is that by the way?
Thanks.
in most cases the PCR is the same as the video PID. If not then 8190 is what works
audio only stations (to show in the audio area) use 8191 for PCR & Video PID
if you look at sathint and to the right of the video pid there is a "I". If you hover on it that will tell you if the PCR is different than the video PID
Reactions: iBoston
Telstar 12 @ 15W Ku
Found this receipt...
