Dishes: Birdview with c/ku using disecq 1 and 2 ports. Channel Master .75 meter for PBS on 125. All (3) fed through disecq controlled by my Openbox, all working fine.
Change: Added motorized Ku to the mix last week. Works fine (signal-wise) if make it input on disecq port 4 directly to the Openbox, but hear I can't run motor through that disecq, so thought I'd run a separate line to it! I ran a dedicated coax line from the new motorized Ku into the receiver, and installed 22khz switch to allow one side to channel the Birdview's disecq containing the combination C & Ku along with the dedicated PBS dish and routed the NEW motorized Ku to the other side of the switch at the receiver needing the 22khz "on."
Surprising result: I received my Birdview's C and Ku, and the switching worked GREAT for going to and from the new motorized dish's line (did not check motion by the way, concerned first with signal.) BUT......for some reason, the stationary dedicated Ku aimed at 125 would not "talk" through the 22khz switch. Switch is a sadoun s-sm21H. LNB at that fixed dish which doesn't work through the switch is the combination circular and linear QPH-031.
What would cause no passing of the LNB from the dedicated PBS dish? (the rest works fine this way!!)
