Adding 3rd receiver to dish 62.5/72.7 setup
teb2500
23
US
I have two cables coming in off my dish 61.5/72.7 that connect to two 222's (too many 2's!) I would like to add another 222 and wanted to see what the options are to connect. Do I need to run a third cable to the lnb or can i connect the two incoming cables to a dpp44 switch and just run the 3 cables to each receiver? I'm not sure if there are conflicts with the two switches in the lnb and dpp44. Any assistance is greatly appreciated. Thanks!
DPP44 switches are kind of expensive. But they do know how to shut off the switch in the LNB and give you four DPP outputs. I think the 1000.2EA LNB has 3 outputs as well, so that would be cheapest.
Either way would work fine.
Like TheKrell said, third line from lnb would be cheaper (unless you already have a 44 switch laying around.
Hopper Pricing on current bill (Feb 2014)
