Adding 118.7 to a dpp44
lcorios
25
Because of line of sight problems I have individual dishes for 110, 119 and 129. Each dish has a dish pro LNB. They are connected to three inputs on a dpp44. The dpp44 runs two receivers, a 722DVR and a 622DVR.
I want to add 118.7 to the fourth input on the dpp44. I have researched everywhere to determine which dual LNB I need to use to replace the LNB on the 119 dish. There appears to be a number of them and I am very confused.
Some (like the ROC LNB Model CST-11G) claim that it works with a dpp44 but the L.O. Freq needs to be set to 10750 on the receiver. Is there a setting for that on the 622 and 722? Also it combines and pushes both the 118 and 119 signals out of each of its two connections. How do I split that for the feed to the dpp44 - or do I need to?
Can you point me to a LNB that I should use?
Replace your 119 dish with a 500+ dish that uses the 500+ LNB for the 119 and 118. As far as I know, that is the only Dish-approved LNB to obtain the 118. The 1F port on the LNB goes to the DPP44 for your 118, the 2D goes to your DPP44 for the 119.
Crank up Dish for RV
Recording Shows from Internet
