actuator stuck
Techfizzle
Banned
985
i moved my dish all the way west now it wont move back east what is going on? the receiver is fine and the dish isnt stuck
Can you give more information?
Does the motor run when you tell the dish to move? Can you hear it make noise?
If not, check the connections.
If the actuator is at one limit of travel, tell the motor to run in the other direction (to a sat in that direction) and while the motor is running, push on the dish (eastward) to re engage the leadscrew.
It's also possible that one of the actuator's limit miniswitches is broken or a bypass diode is blown.
You can use a car battery to move the dish, Put the red to the positive, and the black to negative, if it doesn't move the dish in the right direction, reverse the wires and the dish should move in the other direction.
come to find out, i blew a fuse, the fuse in there was pulled from something, and was a slow-blo. after moving my dish west for 10 seconds at the west limit, thinking i hadnt gone that far, must of heated the fuse til it blew
wierd though, it didnt look blown, but i tested it and it was
Skyvision / Paid Programming ??
Teletext on NSS806
