My wife has a minivan, a 98 Plymouth Grand Voyager (grand caravan, basically) with a 3.0 engine. Radiator is boiling over. The problem is either a hairline crack in a cylinder or a leaking head gasket. The mechanic says the short block needs to be replaced, but he can't do the work, I would have to take it to someone else.
I can't seem to find the paper the mechanic wrote up, or I would put exactly what he said. It was to the effect of the cooling system being over-pressurized by gases getting in to the coolant from the leak. I'm gonna pull the spark plugs next to see if any of them are wet and check the oil to see if any radiator fluid is in there. I'm basically venturing in to an aspect of vehicle repair/diagnosis I've never been to before.
So, the question comes down to, if the short block needs to be replaced, what are some of the deciding factors of whether I should do this or not? The transmission was recently done, less than 15k on it. AC works good, body in good shape, interior in good shape, etc. I do have to slap the dash to get the cluster to come back to life on occasion. There's always been a slight blowby problem, but I assume a new short block would cure that as well?
