9/21/2016 19:16 - Uplink Report - 106 Changes
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 9/21/2016 19:16 - 106 Changes
Uplink Comparison Range: 9/21/2016 09:35 - 9/21/2016 19:16 (PST)
Channel Additions:
6802 - UP4SD [MPEG4 SD] added to Quetzsat1 77W TP 24 ConUS (UP4SD)(NA)(H)
6802 - UP4SD [MPEG4 SD] added to Quetzsat1 77W TP 28 ConUS (UP4SD)(NA)(H)
Channel Removals:
817 - ORDER [MPEG2 SD] (A) (FP) removed from EchoStar14 119W TP 10 ConUS (PPV Event Pre-Order)
817 - ORDER [MPEG4 SD] (A) (FP) removed from Nimiq5 72.7W TP 29 ConUS (PPV Event Pre-Order)
818 - ORDER [MPEG4 HD] (A) (FP) removed from Nimiq5 72.7W TP 29 ConUS (PPV Event Pre-Order)
818 - ORDER [MPEG4 HD] (A) (FP) removed from EchoStar11 110W TP 10 ConUS (PPV Event Pre-Order)
9996 - V-MEK [MPEG2 SD] (NA)(H) removed from EchoStar11 110W TP 09 ConUS (V-MEK)
15950 - WGN9 [Guide Data] (NA)(H) removed from Ciel-2 129W TP 09 Spotbeam 22 (Stn: (CHICAGO,IL-CW) (IL-CW))
15951 - WJW [Guide Data] (NA)(H) removed from Ciel-2 129W TP 01 Spotbeam 25 (Stn: (CLEVELAND,OH-FOX) (OH-FOX))
15952 - KDAF [Guide Data] (NA)(H) removed from EchoStar10 110W TP 29 Spotbeam 21 (Stn: (DALLAS,TX-CW) (TX-CW))
15953 - WQAD [Guide Data] (NA)(H) removed from EchoStar10 110W TP 27 Spotbeam 19 (Stn: (MOLINE,IL-ABC) (IL-ABC))
15954 - KWGN [Guide Data] (NA)(H) removed from Ciel-2 129W TP 04 Spotbeam 19 (Stn: (DENVER,CO-CW) (CO-CW))
15955 - KDVR [Guide Data] (NA)(H) removed from Ciel-2 129W TP 04 Spotbeam 19 (Stn: (DENVER,CO-FOX) (CO-FOX))
15956 - WHO [Guide Data] (NA)(H) removed from Ciel-2 129W TP 01 Spotbeam 21 (Stn: (DES MOINES,IA-NBC) (IA-NBC))
15958 - KFSM [Guide Data] (NA)(H) removed from EchoStar10 110W TP 23 Spotbeam 20 (Stn: (FT SMITH,AR-CBS) (AR-CBS))
15959 - KXNW [Guide Data] (NA)(H) removed from Ciel-2 129W TP 03 Spotbeam 37 (Stn: (EUREKA SPRINGS,AR-MN) (AR-MN))
15960 - WXMI [Guide Data] (NA)(H) removed from Ciel-2 129W TP 13 Spotbeam 22 (Stn: (BATTLE CREEK,MI-FOX) (MI-FOX))
15961 - WGHP [Guide Data] (NA)(H) removed from EchoStar10 110W TP 31 Spotbeam 05 (Stn: (HIGH POINT,NC-FOX) (NC-FOX))
15962 - WPMT [Guide Data] (NA)(H) removed from EchoStar10 110W TP 18 Spotbeam 04 (Stn: (YORK,PA-FOX) (PA-FOX))
15963 - KIAH [Guide Data] (NA)(H) removed from EchoStar14 119W TP 04 Spotbeam B11 (Stn: (HOUSTON,TX-CW) (TX-CW))
15964 - WHNT [Guide Data] (NA)(H) removed from EchoStar14 119W TP 05 Spotbeam B15 (Stn: (HUNTSVILLE,AL-CBS) (AL-CBS))
15965 - WCCT [Guide Data] (NA)(H) removed from EchoStar14 119W TP 04 Spotbeam B17 (Stn: (WATERBURY,CT-CW) (CT-CW))
15966 - WTIC [Guide Data] (NA)(H) removed from EchoStar14 119W TP 04 Spotbeam B17 (Stn: (HARTFORD,CT-FOX) (CT-FOX))
15967 - WTTV [Guide Data] (NA)(H) removed from EchoStar10 110W TP 18 Spotbeam 13 (Stn: (BLOOMINGTON,IN-CW) (IN-CW))
15968 - WXIN [Guide Data] (NA)(H) removed from Ciel-2 129W TP 05 Spotbeam 24 (Stn: (INDIANAPOLIS,IN-FOX) (IN-FOX))
15969 - WDAF [Guide Data] (NA)(H) removed from Ciel-2 129W TP 04 Spotbeam 29 (Stn: (KANSAS CITY,MO-FOX) (MO-FOX))
15970 - KTLA [Guide Data] (NA)(H) removed from Ciel-2 129W TP 04 Spotbeam 33 (Stn: (LOS ANGELES,CA-CW) (CA-CW))
15971 - WREG [Guide Data] (NA)(H) removed from Ciel-2 129W TP 16 Spotbeam 38 (Stn: (MEMPHIS,TN-CBS) (TN-CBS))
15972 - WSFL [Guide Data] (NA)(H) removed from EchoStar14 119W TP 02 Spotbeam B20 (Stn: (MIAMI,FL-CW) (FL-CW))
15973 - WITI [Guide Data] (NA)(H) removed from EchoStar10 110W TP 04 Spotbeam 18 (Stn: (MILWAUKEE,WI-FOX) (WI-FOX))
15974 - WTKR [Guide Data] (NA)(H) removed from Ciel-2 129W TP 03 Spotbeam 40 (Stn: (NORFOLK,VA-CBS) (VA-CBS))
15975 - WGNT [Guide Data] (NA)(H) removed from Ciel-2 129W TP 03 Spotbeam 40 (Stn: (PORTSMOUTH,VA-CW) (VA-CW))
15976 - WGNO [Guide Data] (NA)(H) removed from EchoStar10 110W TP 23 Spotbeam 12 (Stn: (NEW ORLEANS,LA-ABC) (LA-ABC))
15977 - WNOL [Guide Data] (NA)(H) removed from EchoStar10 110W TP 23 Spotbeam 12 (Stn: (NEW ORLEANS,LA-CW) (LA-CW))
15978 - WPIX [Guide Data] (NA)(H) removed from Echostar16 61.5W TP 22 Spotbeam 02 (Stn: (NEW YORK,NY-CW) (NY-CW))
15979 - KAUT [Guide Data] (NA)(H) removed from Ciel-2 129W TP 09 Spotbeam 36 (Stn: (OKLAHOMA CITY,OK-MN) (OK-MN))
15980 - KFOR [Guide Data] (NA)(H) removed from Ciel-2 129W TP 09 Spotbeam 36 (Stn: (OKLAHOMA CITY,OK-NBC) (OK-NBC))
15981 - WPHL [Guide Data] (NA)(H) removed from EchoStar10 110W TP 12 Spotbeam 04 (Stn: (PHILIDELPHIA,PA-MN) (PA-MN))
15982 - KRCW [Guide Data] (NA)(H) removed from EchoStar10 110W TP 29 Spotbeam 44 (Stn: (PORTLAND,OR-CW) (OR-CW))
15983 - WTVR [Guide Data] (NA)(H) removed from Ciel-2 129W TP 14 Spotbeam 40 (Stn: (RICHMOND,VA-CBS) (VA-CBS))
15984 - KTXL [Guide Data] (NA)(H) removed from EchoStar10 110W TP 18 Spotbeam 43 (Stn: (SACRAMENTO,CA-FOX) (CA-FOX))
15985 - WNEP [Guide Data] (NA)(H) removed from EchoStar14 119W TP 03 Spotbeam B16 (Stn: (SCRANTON,PA-ABC) (PA-ABC))
15986 - KSWB [Guide Data] (NA)(H) removed from EchoStar10 110W TP 29 Spotbeam 39 (Stn: (SAN DIEGO,CA-FOX) (CA-FOX))
15987 - KCPQ [Guide Data] (NA)(H) removed from EchoStar14 119W TP 05 Spotbeam A1 (Stn: (TACOMA,WA-FOX) (WA-FOX))
15988 - KZJO [Guide Data] (NA)(H) removed from EchoStar14 119W TP 05 Spotbeam A1 (Stn: (SEATTLE,WA-IND) (WA-IND))
15989 - KSTU [Guide Data] (NA)(H) removed from Ciel-2 129W TP 01 Spotbeam 18 (Stn: (SALT LAKE CITY,UT-FOX) (UT-FOX))
15990 - KTVI [Guide Data] (NA)(H) removed from Ciel-2 129W TP 10 Spotbeam 30 (Stn: (ST LOUIS,MO-FOX) (MO-FOX))
15991 - KPLR [Guide Data] (NA)(H) removed from Ciel-2 129W TP 10 Spotbeam 30 (Stn: (ST LOUIS,MO-CW) (MO-CW))
15992 - WDCW [Guide Data] (NA)(H) removed from EchoStar10 110W TP 25 Spotbeam 05 (Stn: (WASHINGTON,DC-CW) (DC-CW))
MAP Changed:
4971(9) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4971(9) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4972(9) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4972(9) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4973(32) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (32) removed (Dish Network Information Channel)(NA)(H)
4973(32) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (32) removed (Dish Network Information Channel)(NA)(H)
4974(14) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4974(14) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4975(6) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4975(6) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (6) removed (Dish Network Information Channel)(NA)(H)
4976(18) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (18) removed (Dish Network Information Channel)(NA)(H)
4976(18) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (18) removed (Dish Network Information Channel)(NA)(H)
4977(9) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4977(9) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (9) removed (Dish Network Information Channel)(NA)(H)
4978(44) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (44) removed (Dish Network Information Channel)(NA)(H)
4978(44) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (44) removed (Dish Network Information Channel)(NA)(H)
4979(62) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (62) removed (Dish Network Information Channel)(NA)(H)
4979(62) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (62) removed (Dish Network Information Channel)(NA)(H)
4980(20) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (20) removed (Dish Network Information Channel)(NA)(H)
4980(20) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (20) removed (Dish Network Information Channel)(NA)(H)
4981(5) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4981(5) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4982(3) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4982(3) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4983(4) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
4983(4) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (4) removed (Dish Network Information Channel)(NA)(H)
4984(7) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
4984(7) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
4985(27) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (27) removed (Dish Network Information Channel)(NA)(H)
4985(27) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (27) removed (Dish Network Information Channel)(NA)(H)
4986(5) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4986(5) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (5) removed (Dish Network Information Channel)(NA)(H)
4987(3) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4987(3) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4988(7) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
4988(7) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (7) removed (Dish Network Information Channel)(NA)(H)
4989(41) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (41) removed (Dish Network Information Channel)(NA)(H)
4989(41) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (41) removed (Dish Network Information Channel)(NA)(H)
4990(14) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4990(14) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4991(68) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (68) removed (Dish Network Information Channel)(NA)(H)
4991(68) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (68) removed (Dish Network Information Channel)(NA)(H)
4992(14) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4992(14) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (14) removed (Dish Network Information Channel)(NA)(H)
4993(3) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4993(3) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (3) removed (Dish Network Information Channel)(NA)(H)
4994(17) - LOCAL [MPEG2 SD] EchoStar14 119W TP 14 ConUS renamed to DISH , changed to Not Available , map (17) removed (Dish Network Information Channel)(NA)(H)
4994(17) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 22 ConUS renamed to DISH , changed to Not Available , map (17) removed (Dish Network Information Channel)(NA)(H)
6941(10) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 31 ConUS renamed to DISH , changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
6941(10) - LOCAL [MPEG2 SD] EchoStar11 110W TP 02 ConUS renamed to DISH , changed to Not Available , map (10) removed (Dish Network Information Channel)(NA)(H)
6942(8) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 31 ConUS renamed to DISH , changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
6942(8) - LOCAL [MPEG2 SD] EchoStar11 110W TP 02 ConUS renamed to DISH , changed to Not Available , map (8) removed (Dish Network Information Channel)(NA)(H)
6943(12) - LOCAL [MPEG4 SD] Nimiq5 72.7W TP 31 ConUS renamed to DISH , changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
6943(12) - LOCAL [MPEG2 SD] EchoStar11 110W TP 02 ConUS renamed to DISH , changed to Not Available , map (12) removed (Dish Network Information Channel)(NA)(H)
Name Changed:
5206(15) - KCZ [MPEG4 HD] Echostar16 61.5W TP 18 Spotbeam 63 renamed to KYCW (KYCW)(Mkt: Springfield,MO)(A)(H)
5206(15) - KCZ [MPEG4 HD] Quetzsat1 77W TP 32 ConUS renamed to KYCW (KYCW)(Mkt: Springfield,MO)(A)(H)
7225(15) - KCZ [MPEG2 SD] EchoStar10 110W TP 12 Spotbeam 20 renamed to KYCW (KYCW)(Mkt: Springfield,MO)(A)(H)
Transponder Changes:
Quetzsat1 77W TP 24 ConUS (22.500 16-QAM 5/6) added.
Quetzsat1 77W TP 28 ConUS (22.500 16-QAM 5/6) added.
EchoStar14 119W TP 10 ConUS (21.500 8PSK 2/3) removed.
EchoStar11 110W TP 09 ConUS (21.500 8PSK 2/3) removed.
EchoStar11 110W TP 10 ConUS (21.500 8PSK 2/3) removed.
Nimiq5 72.7W TP 29 ConUS (21.500 8PSK 2/3) removed.
Channels in the system: 9563
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2016 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.2
© 2016 - All Rights Reserved - SatelliteGuys Incorporated
9/15/2016 09:44 - Uplink Report - 2 Changes
9/25/2016 19:58 - Uplink Report - 2 Changes
