I got up at 4:00 AM this morning so I could be on the roof early while it was still cool.
I put the dish that was freed up from the family setup in place yesterday morning, and set it up on my TS satellite at 91W. Got the National Labs test card at 75% SQ, and that was where I left it. I thought maybe if I point the dish in between the two satellites I was going to try for, It might make things a little easier.
The elevation on 91W (G11) is 44.90 degrees, 87W (AMC3) elevation is 44.70, and 97W (G25) is 44.40. I thought this will work out perfectly. I can set it on 91W, and both LNBFs will be higher and it will be very easy to set.
I was surprised to find that when I put the LNBF for AMC3 on, I couldn't get a signal of any kind no matter if I slid it East or West on the bracket, or up and down, nothing. I was using the strongest TP on AMC3 which is 11799 H. So I took the bottom nut off the holding bolt, and took the LNBF out of the bracket, and set it down on the bottom of the LNBF resting on the bracket, and BAM had 75% SQ. I marked the spot on the side bracket, and put the LNBF back on and semi-tightened down.
I thought if you can't raise the bridge, you can lower the river, and decided to try lowering the elevation on the dish to allow for the tightening nuts etc to fit under the LNBF. Lowered up to 6 degrees and nothing. I had marked the elevation on the side of the dish from where I started, so I cranked it back up to there. I sat there for a few minutes, and thought, now what?
So I thought what the heck, I'll try raising the elevation on the dish. After a couple of degrees of raising, I began to get a signal. So I peaked the elevation, and then began adjusting the holding bolt.
I ended up with the above TP at 99% but Montana PBS was only at 30%. They are both Horizontal so I adjusted the skew a little. For all those reading, skew makes all the difference in the world. I finally settled at Montana PBS at 45%, but the Vertical PBS channels are at 60% SQ, so that made me happy. I guess the Horizontal channels with lower signals are a little different when the dish is not at the center.
I then hooked up G25, and I didn't even have to move the LNBF. I had signal on 11935 H. From there it was just a matter of fine tuning with East/West and up/down movements, and finally skew until I was finally satisfied.
Games N Flix is at 75% SQ and all else falls in place from there. The Church channel is in the nineties.
I was very surprised that I had to raise the dish instead of lowering. Maybe some of you physics guys out there can tell me the answer to that one?
Here are the pics:
After looking at the pictures, another question arises in my mind. Why is the LNB for G25 (6 degrees from center) closer to the bracket (lower) and lower elevation than the one for AMC3 (4 degrees from center)? The only answer I can think of is that the angle is steeper for the satellite which is closer. What answers do you have?
I would have liked to have tried for 79W (AMC5) just to see if I can get it on the same dish. I don't know of a way to add it to my Pansat setup though, so I didn't try.
Remember the new LNBFs are Universals, and they are all coming in on the 22Khz side turned on of my Ecoda switch. I now have 4 LNBs on the the 0Khz side of the Ecoda switch and 4 on the 22Khz on side of that switch.
The Pansat only has 4 ports in the setup screen, and 22Khz switch on or off.
If any of you know of a way for me to add more LNBFs to this setup, please post it here?
For those of you interested, these two pictures are of my dish farms. The first one is of the Northern dish farm, and the second is the Southern dish farm.
I have plenty of space in the middle for another BUD which I am going to try and add by Fall.
Fred
Here are the pics:
Fred
