D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 8/22/2009 5:09pm - 31 changes
Uplink Comparison Range: 08/22/2009 04:54P - 08/22/2009 05:08P
Channel Moves:
576 - ZEESA [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
583 - RADIO [MPEG AUDIO] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
584 - SAMAY [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
585 - AAJTK [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
586 - HT [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
617 - ZCINE [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
619 - B4U [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
624 - SHARA [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
659 - DUBSP [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
665 - ZIKR [MPEG AUDIO] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
672 - DANDA [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
673 - MZIKA [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
767 - ABUDA [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
769 - DREAM [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A)
783 - NORST [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (A) (H)
5834 - TST25 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5835 - TST26 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5866 - TST01 [SD TV] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5867 - TST02 [SD TV] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5868 - TST03 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5869 - TST04 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5870 - TST05 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5871 - TST06 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5872 - TST07 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5873 - TST08 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5874 - TST09 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5875 - TST10 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5876 - TST11 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
5877 - TST12 [MPEG2 SD] moved from EchoStar3 61.5W TP 12 ConUS beam to Echostar12 61.5W TP 21 ConUS beam (NA)
Transponder Changes:
Echostar12 61.5W TP 21 ConUS beam 20000 QPSK 5/6 added
EchoStar3 61.5W TP 12 ConUS beam 20000 QPSK 5/6 removed
Channels in the system: 6627
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
Channel Moves:
