I was curious if you had any ideas on why the following issue is occuring.
I am using a 722k with Sling adapter and the correct Dish Wireless Adapter. It's set up and I have verified Internet Connectivity in Broadband setup. I have also verified that my 3Mbps DSL connection is appropriate by running the Sling verifyer on the Dish website.
The issue I am having is that from any device most of the time it says my DVR Receiver is off and therefore it cannot stream any Recordings to my device. However, if I hit LiveTV it will Start up the DVR (Even if it's off), authenticate with it and stream LiveTV no problem. Now knowing that the DVR is in fact on, I go to the DVR status in the iOS app or PC app and it still says offline. The Guide will not allow me to select a channel and watch LiveTV, the only thing that works is hitting the LiveTV button.
The only way I can get the DVR to stream recordings is by cutting power for 10 seconds and booting it up, it will then usually say the DVR is online and let me stream recordings or switch channels using the guide.
To summarize my problem:
The DVR will state that it is offline in all of the Dish Online apps. Using the Reconnect button does not work.
The LiveTV button works fine all of the time, even turning on the DVR when it is off or in sleep mode. Regardless, this does not affect its online status in the Dish Online apps.
Can usually only get the DVR to appear online if I cut power to the box for 10 seconds, however, after a few hours it goes back to a status of Offline and stays that way, regardless of if its actually on or not.
Hardware: 722k DVR, Sling Adapter, and Dish Wireless Adapter (with good signal).
Thanks!
I searched for similar threads and found a couple about the 722 not being detected online, however, no thread had a solid resolution. If this problem has been resolved if you could please direct me to the resolution that would be great.
Thanks!
