I've noticed on my 722K there is usually a small difference (2 - 3 points) between the two OTA tuners on the same channel (bring up PIP and tune to the same OTA channel in each window, then SWAP to get signal strength) perhaps due to the splitting of the OTA signal inside the tuner module. I've got one channel that sometimes displays 10 - 12 points difference at some times, then goes back to the small difference at other times.
I've also noticed the signal strength meter in the OTA menu used to scan and enter/delete OTA channels many times will show a different signal level (higher) than either of the two tuners when watching video.
What have other 722K folks noticed on this if you've had a look?
Thanks,
Doug
Thanks,
Doug
