7/23/2009 2:14am - Uplink Activity Report - 57 changes
D
DigiDish Uplink Report
Guest
SatelliteGuys.US DishNetwork Uplink Activity Report - 7/23/2009 2:14am - 57 changes
Uplink Comparison Range: 07/23/2009 01:59A - 07/23/2009 02:14A
Channel Removals:
555 - DMOS6 (NA) removed from EchoStar11 110W TP 16 ConUS beam
555 - DMOS6 (NA) removed from Echostar6 72.7W TP 29 ConUS beam
4130 - TMP10 (NA) removed from Echostar12 61.5W TP 21 ConUS beam
4816 - TMP46 (NA) removed from EchoStar8 77W TP 32 ConUS beam
4820 - TMP50 (NA) removed from EchoStar8 77W TP 32 ConUS beam
Channel Moves:
103 - PPV [MPEG2 SD] moved from EchoStar7 119W TP 06 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
173 - DISW [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 06 ConUS beam (A)
302 - HBOSG [MPEG2 SD] moved from EchoStar7 119W TP 06 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
328 - TMCXE [MPEG2 SD] moved from EchoStar7 119W TP 17 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
333 - FLIX [MPEG2 SD] moved from EchoStar7 119W TP 17 ConUS beam to EchoStar7 119W TP 06 ConUS beam (A)
387 - CI [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A)
387 - CI [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 13 ConUS beam (A)
410 - ALTUD [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 17 ConUS beam (A) (H)
413 - MSG+ [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 16 ConUS beam (A) (H)
414 - FOXRM [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A) (H)
416 - FOXSW [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 12 ConUS beam (A) (H)
419 - CSNBA [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 17 ConUS beam (A) (H)
420 - FOXS [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 16 ConUS beam (A) (H)
426 - FOXNW [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 21 ConUS beam (A) (H)
429 - CSNCH [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 17 ConUS beam (A) (H)
502 - PPV [MPEG2 SD] moved from EchoStar7 119W TP 06 ConUS beam to EchoStar7 119W TP 04 ConUS beam (A)
539 - HDPPV [MPEG4 HD] moved from EchoStar8 77W TP 32 ConUS beam to EchoStar8 77W TP 28 ConUS beam (A)
600 - RAI [MPEG2 SD] moved from EchoStar7 119W TP 04 ConUS beam to EchoStar7 119W TP 06 ConUS beam (A)
980 - CD 31 [MPEG AUDIO] moved from EchoStar7 119W TP 17 ConUS beam to EchoStar7 119W TP 13 ConUS beam (A)
4152 - CBS C [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A) (H)
4152 - CBS C [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 13 ConUS beam (A) (H)
4194 - GREEN [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A) (H)
4194 - GREEN [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 13 ConUS beam (A) (H)
4239 - WGN [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A) (H)
4239 - WGN [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 13 ConUS beam (A) (H)
4287 - CI [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A) (H)
4287 - CI [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 13 ConUS beam (A) (H)
4820 - TMP50 [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to Ciel-2 129W TP 24 ConUS beam (NA)
5327 - WGN [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A) (H)
5327 - WGN [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 13 ConUS beam (A) (H)
5815 - EPSK2 [MPEG2 SD] moved from EchoStar7 119W TP 10 ConUS beam to EchoStar7 119W TP 18 ConUS beam (NA)
5816 - VOD [VOD] moved from EchoStar7 119W TP 06 ConUS beam to EchoStar7 119W TP 04 ConUS beam (NA)
5898 - DRMT2 [MPEG2 SD] moved from EchoStar7 119W TP 06 ConUS beam to EchoStar7 119W TP 04 ConUS beam (NA)
5899 - DRMT3 [MPEG2 SD] moved from EchoStar7 119W TP 06 ConUS beam to EchoStar7 119W TP 04 ConUS beam (NA)
9055 - WAWSD [MPEG4 SD] moved from EchoStar8 77W TP 13 ConUS beam to EchoStar8 77W TP 17 ConUS beam (A) (H)(Jacksonville, FL-FOX)
9446 - WGN [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A)
9446 - WGN [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 13 ConUS beam (A)
9457 - GREEN [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A)
9457 - GREEN [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 13 ConUS beam (A)
9481 - TMC-E [MPEG4 HD] moved from Ciel-2 129W TP 24 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A)
9481 - TMC-E [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 13 ConUS beam (A)
9495 - CBS C [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A)
9495 - CBS C [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 13 ConUS beam (A)
9496 - SEDGE [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A) (H)
9496 - SEDGE [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 32 ConUS beam (A) (H)
9498 - STRZW [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A) (H)
9498 - STRZW [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 32 ConUS beam (A) (H)
9505 - ENCOR [MPEG4 HD] moved from Ciel-2 129W TP 20 ConUS beam to EchoStar11 110W TP 19 ConUS beam (A) (H)
9505 - ENCOR [MPEG4 HD] moved from Echostar12 61.5W TP 21 ConUS beam to EchoStar8 77W TP 32 ConUS beam (A) (H)
Transponder Changes:
EchoStar7 119W TP 10 ConUS beam 20000 QPSK 5/6 removed
Ciel-2 129W TP 20 ConUS beam 21500 8PSK 2/3 removed
Echostar12 61.5W TP 21 ConUS beam 21500 8PSK 2/3 removed
Channels in the system: 6754
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
In Puerto Rico
My vip is showing the hd channels form 110 on red WGN, GREEN, CI and says it's a sub. channel.
Hope when the new package of hd starts for us they will add these channels
In Puerto Rico
That's what I've been hoping for. There is no reason for them not to be, since the signal is strong and basically everybody is aligned to 110. But Dish did not mentioned them in the chat... Come on Dish, you just have to flip the switch....
The HD premiums are coming loud and clear. Nice.
In Puerto Rico
Not only that, they could eliminate the MPEG4 SD WGN channel, making a little room in spotbeam 29. There wont be room for another HD, but there could be more room for another local.
My count of moves is 59:
Code:
#	Number	Name	Sat	TID	ST	LiL/Map	Market	EPG	Status	Arc
Moved: 59
	103	PPV	119	4	9A	0	0	-		WA
	146	ESP2A	119	18	9A	0	0	-		WA
	147	ESPNA	119	18	9A	0	0	-		WA
	173	DISW	119	6	9A	0	0	-		WA
	302	HBOSG	119	4	9A	0	0	-		WA
	328	TMCXE	119	4	9A	0	0	-		WA
	333	FLIX	119	6	9A	0	0	-		WA
	387	CI	110	219	A4	0	0	-		WA
	387	CI	77	813	A4	0	0	-		EA
	410	ALTUD	119	17	9A	0	0	+		WA
	413	MSG+	119	16	9A	0	0	+		WA
	414	FOXRM	119	4	9A	0	0	+		WA
	416	FOXSW	119	12	9A	0	0	+		WA
	419	CSNBA	119	17	9A	0	0	+		WA
	420	FOXS	119	16	9A	0	0	+		WA
	426	FOXNW	119	21	9A	0	0	+		WA
	429	CSNCH	119	17	9A	0	0	+		WA
	455	SPORT	119	13	9A	0	0	-		WA
	475	ALT	119	17	9A	0	0	+		WA
	502	PPV	119	4	9A	0	0	-		WA
	539	HDPPV	77	828	A4	0	0	-		EA
	562	NBA	119	16	9A	0	0	+		WA
	600	RAI	119	6	9A	0	0	-		WA
	630	NHL	119	16	9A	0	0	+		WA
	631	NHL	119	16	9A	0	0	+		WA
	633	NHL	119	16	9A	0	0	+		WA
	634	NHL	119	16	9A	0	0	+		WA
	980	CD 31	119	13	2	0	0	-		WA
	4152	CBS C	110	219	A4	152	250	+		WA
	4152	CBS C	77	813	A4	152	250	+		EA
	4194	GREEN	110	219	A4	194	250	+		WA
	4194	GREEN	77	813	A4	194	250	+		EA
	4239	WGN	110	219	A4	0	0	+		WA
	4239	WGN	77	813	A4	0	0	+		EA
	4287	CI	110	219	A4	387	250	+		WA
	4287	CI	77	813	A4	387	250	+		EA
	4820	TMP50	129	424	A4	0	0	+		WA
	5327	WGN	110	219	A4	0	0	+		WA
	5327	WGN	77	813	A4	0	0	+		EA
	5815	EPSK2	119	18	9A	0	0	+		WA
	5816	VOD	119	4	A2	0	0	+	fta	WA
	5898	DRMT2	119	4	9A	0	0	+		WA
	5899	DRMT3	119	4	9A	0	0	+		WA
	9055	WAWSD	77	817	A8	32	95	+		EA
	9446	WGN	110	219	A4	239	250	-		WA
	9446	WGN	77	813	A4	239	250	-		EA
	9457	GREEN	110	219	A4	194	250	-		WA
	9457	GREEN	77	813	A4	194	250	-		EA
	9481	TMC-E	110	219	A4	327	250	-		WA
	9481	TMC-E	77	813	A4	327	250	-		EA
	9495	CBS C	110	219	A4	152	250	-		WA
	9495	CBS C	77	813	A4	152	250	-		EA
	9496	SEDGE	110	219	A4	352	250	+		WA
	9496	SEDGE	77	832	A4	352	250	+		EA
	9498	STRZW	110	219	A4	351	250	+		WA
	9498	STRZW	77	832	A4	351	250	+		EA
	9505	ENCOR	110	219	A4	340	250	+		WA
	9505	ENCOR	77	832	A4	340	250	+		EA
	9801	SPORT	119	13	9A	0	0	+		WA
Deleted: 5
	4130	TMP10	61.5	121	A4	0	0	+		EA
	555	DMOS6	110	216	9A	0	0	+		WA
	4816	TMP46	77	832	A4	0	0	+		EA
	4820	TMP50	77	832	A4	0	0	+		EA
	555	DMOS6	72.7	929	A8	0	0	+		EA
Without know a reason we can't be so sure, as we just interpreting results of multistage process, I would say, what is not that intuitive clear. I would dig into it later.
And what I do see is very, very good. I don't understand this continual banter about what everyone believes is a great tool from digi and only you seem to take some kind of nitpick attitude about.
Smith P always nitpicks on Digiblur and I don't get it.
I'm stoked that the HI/AK HD premium count just jumped from 3 to 7!:) Yahoo!
CI and GREEN are new to us, but CBS-C and WGN are already on our 110 spot(all 4 are redded out in the guide). That makes 2 duplicates on the 110 spot and 10 on the 129 spot.
We could get all the missing prems (SK&FM, SHOTO, SHOCS, HBOCY, HBOZ, HBOFM, HBOSG, HBO2, 5-MAX, ACMAX) plus MSNBC and PLDIA without using a bit more bandwidth. ;)
stay on topic, please
Actually, it is about parsing, processing and software rules, not about me and digi ! Is it simple ?
Why each time when technical details comes to discuss some "smart" boy comes up with such sick personal comment ? !
Perhaps enough to stirring the pot ? - it's happening not first time and each time as a perversion :down
seems like YOU are the only one with an issue on how the reports are done. I and others think they look pretty dang good. It gives us the info we need. I dont need to see all those sports moves each day
That's OK for your personal preferences, but what if other member here likes to know the movements ? More, I merely pointed to unusual time for such sport channels movement.
And again, the discussion was civil up to the moment when the OFF-TOPIC comments appeared. Practically ended before the nastiness heated up.
WHY ?
Who is the bobby ? Is he understand parsing of DVB tables ? Is he understand the tech talk at all ? Perhaps not, if he came to the wrong conclusion about nitpicking.
We should stop the useless line...
D
7/24/2009 5:14am - Uplink Activity Report - 1 change
D
7/25/2009 5:14am - Uplink Activity Report - 1 change
Similar threads
D
Replies
Views
2K
D
D
Replies
Views
2K
D
