Here is what I have:
Dish 500 pointing at 61.5 with DP dual LNB. I ran one cable (no switch) to 301 receiver and ran check switch. Got an error message and was only able to see ODD polarity. I couldn't get all of my subscribed channels. So, I put in SW21 and connected 2 cables from LNB to SW21 with one cable run back to receiver. I was able to see all channels. I am confused... I thought I would only need cable run if I am using DP dual? Am I missing something here? The LNB is connected using "Y" arm. Would it make a difference if I use "I" arm?
I repeated the same setup as above but now used 510 receiver. I couldn't get signal at all. Do I need to change SW21 to DP21 if I use 510 receiver?
Thanks for the help
Thanks for the help
