That is "Old School" actuator cable. Nobody makes that anymore. But the comment "all" are hooked to the actuator suggests that you have a three wire sensor in that actuator and not a two wire reed sensor. If so, you may have to make some considerations on a controller for that actuator or convert it to a reed sensor. The best choice for sensor wiring would be shielded cable used in security systems. Motor wiring can be 16 - 12 gauge two lead unshielded cable.By the way these are all hooked to the actuator arm.
Off the wire topic but what receiver is a good choice to go with my Titanium ASC1?
I agree with Magic Static - and I will heavily insist on the need for the sensor cable to be shielded. Unshielded cable would get electromagnetic noise from the motor cable or others, and mess up the pulse count.
I used 4-22 shielded alarm cable. If I had to re-do it, i'd try to go with 2-18 or 4-18 instead. 22-gauge is just a bit annoying to work with. For the motor cable I used 14-gauge speaker wire (copper, not aluminum).
can you post a picture of the inside of the actuator connection box, so we can see how that old cable is connected and hopefully see the type of sensor?
I ordered the mini from Michaels today. Did a little reading on it in KE4EST thread. Thanks again Prime!!!You can't get much better than this one, though it comes with a bit of a learning curve. However, if you haven't had any real FTA receiver for some time, it's not much harder to learn than a regular appliance type receiver: Titanium Satellite - Store
IF you want one cheaper, but not as full-featured as the above one, this one is a good choice: Welcome to Michael Electronics
