Last Thursday, I was supposed to have my Phase III upgraded to the 5LNB.
My existing dish is mounted to the fascia of my home. It has been this way since 2004 and I have had 0 problems. It's nice, clean, out of the way, and unobtrusive.
Pictures:
(Pictures Removed, was causing error for members)
When the installer arrived, he took one look at it and said he need to reschedule as he did not bring a 40' ladder for a roof install, did not have the materials for a pole install and would not install on the fascia per DirecTV instructions.
According to him, the added weight of the 5 LNB dish has "ripped" the siding off of other peoples homes in strong winds. I don't doubt that, but I also know (the guy behind me has the 5LNB mounted to the side of his house) that some people have it mounted there with no problems. My neighbor replaced the mounting bracket with the special 5LNB one and just attached the top of the bracket to the fascia leaving the bottom two holes unattached. I was thinking of doing the same. Does that sound right?
I recognize that the 5LNB is substantially larger and heavier, but this doesn't seem right. I have downloaded the 5LNB manual and it clearly shows the dish mounted to the side of a house. Maybe this is in reference to mounting on brick? My house, as the pictures show is all vinyl.
This is my preferred method - roof mount is out; I don't need any leaks or problems from damaged shingles, I'm reluctant to let these clowns install a pole in my yard; will they dig down deep enough, will the concrete have time to set, what about drainage and heaving?
My question: given the size and weight of the new dish, and the materials of my house, I recognize that a pole mount is the preferred method of install. But, if the install is done properly, wouldn't a fascia mount with the bracing arms be just as good?
If you guys advise a pole mount, I'll happily pay them to do one, but I want to be sure before I go down that path.
They're coming back out tomorrow between 8AM and 12:00PM, so I need to know if I should argue for a fascia mount or accept the pole mount.
Pictures:
