My setup consists of a Viewsat Ultra, phase 3 dish, and that is it for the time being. I am first trying to get 3 sats 91, 101, 110. I want 101 so that I can later add the sub to this dish.
Anyway, the problem I am having is that when I am in the Antenna setup menu, I choose bird 110. I get no lock, but when I change the bird to 121, I get a lock on 110. Change it back to 110, and loose the lock. Oh, when I say lock, I am referring to the top right hand corner of the screen (where it shows what bird you are pointing at). I have used the sat calculator located here:
http://satcalculator.freehostia.com/
which seems to be extremely accurate by using the google map to zoom in and point at my house. I have set the skew and the elevation on the dish and plumbed the mounting arm, so that the only thing I have to move is the azimuth. Of course, once I get a signal, I will tweak to get just right. I did try and setup on my sub receiver, and got a lock. I then changed receivers to the Viewsat, and got the problem I am having now. My settings that give me no lock are:
Satellite EchoStar 8,10 110.0W
LNB Power On
LNB Type Universal
LNB High 10600
LNB Low 9750
TP Freq. 12224
Diseq Off
Legacy SW None
My settings that give me a lock on 110 are:
Satellite EchoStar 9 121.0W
LNB Power On
LNB Type Universal
LNB High 10600
LNB Low 9750
TP Freq. 12224
Diseq Off
Legacy SW None
What should I change? Thanks for the help!
LNB Power On
LNB Type Universal
LNB High 10600
LNB Low 9750
TP Freq. 12224
Diseq Off
Legacy SW None
LNB Power On
LNB Type Universal
LNB High 10600
LNB Low 9750
TP Freq. 12224
Diseq Off
Legacy SW None
