my diseqc switch will switch from ku to c band on every satellite but 95W,i have to leave where i am centered on 101W and come back and get centered again and then it will come in.This is frustrating,is this a bad switch?
seems like that should be the problem but it's not.Everything is set up accordingly,i have changed ports and and the same thing happens,guess i'll buy a better switch.your 4X 1 diesqc switch works on every other satellite except 1 , is this setup using the same ports for ku on all satellites and same port for c-band on all satellites . if so i would suspect the receiver satellite setup on the 1 satellite you have trouble with.
