The best way to do this is using a 44 switch make sure 105 or 121 is on the number 4 input.sallgdon64 said:If I use two dp34s to combine the signals from a Superdish and a 61.5 dish, do I use the receiver output jack of first dp34 or the one intended for cascading? That is - the bottom jacks or the right jacks?
The outputs on the right are for trunking, a way to add more tuner outputs, as shown in the diagram on the DP34. Cascading is a different way to combine switches to add an additional satellite input but no additional outputs.sallgdon64 said:If I use two dp34s to combine the signals from a Superdish and a 61.5 dish, do I use the receiver output jack of first dp34 or the one intended for cascading? That is - the bottom jacks or the right jacks?
ke4est said:Never tried this, but does anyone know if the dp34 +dp21 will work on a 301?
In order to get four sats.
I have done this several times on 311's and 811's.
But what about the 301?
