WS International DMX5421 Single Ku Band Linear FSS Monoblock LNBF - 4 degrees
The DMX5421 is a 4° monoblock that is designed to receive signal from satellites within 4°-4.3°. This eliminated having to install a plastic bracket, DiSEqC switch, and an additional LNBF, installing a motor, or multiple satellite dishes.
Pickup all the Free To Air FTA Christian TV stations via 1 satellite dish!!!!!
Pickup both Galaxy 19 at 97° W and AMC 4 at 101° W at the same time using the same satellite dish.
This unit has the popular WS2120 2X1 DiSEqC switch used in our DMX741U LNBF built in for reliable switching between the two satellites.
If you'd like to get private label cost or wholesale pricing, please visit WS International Global Satellite Distribution. or email sales@wsidigital.com
If you are an end-user and would like retail pricing, please visit www.Galaxy-Marketing.com | 1-888-333-5560 or email sales@galax-marketing.com
You are welcome to contact us toll free at 1-888-276-6436 or if you are calling internationally, please call us at +770-420-5272.
Receive signal from any of this satellite combination with
only 1 dish!
79°W & 83°W
83°W & 87°W
85°W & 89°W
87°W & 91°W
89°W & 93°W
91°W & 95°W
93°W & 97°W
95°W & 99°W
97°W & 101°W
101°W & 105°W
107°W & 111°W
113°W & 116.8°W
123°W & 127°W
7°W & 11°W
11°W & 15°W
4.8°E - 9°E
16°E - 19.2°E
19.2°E - 23.5°E
21.6°E - 26°E
40°E - 36°E
WS International is the original manufacturer of the DMX5421 Ku band LNBF
Need to order in large quantities? WS International can private label this LNBF for you!
Technical Specifications
Input Frequency Range
10.70 - 12.75 GHz
L.O. Frequency
Low: 9750MHz
High: 10600MHz
L.O. Stability
1 MHz (-40 - +70° c)
Degree Spacing 4°
Ouput Frequency Range
950 - 2150 MHz
Noise
0.4 dB typical
Conversion Gain
60 dB typical
Input VSWR
2.5:1
Output VSWR
2.0:1 (max)
Connector
F Type female
Impedence
75 ohm typical
Cross Polar Isolation
>25dB (min.)
Image Rejection
45 dB (min.)
Phase Noise
-50dBc @ 1 KHz
-75dBc @ 10 KHz
-95dBc @ 100KHz
Supply Voltage
11.5 - 14.0V = Vertical Polarization
15.5 - 19.0V = Horizontal Polarization
Operating Temperature
-40 - +70 degrees Celsius
Storage Temperature
-40 - +80 degrees Celsius
Relative Humidity
0 - 95 %
Throat Diameter
40mm
