4/20/2015 09:55 - Uplink Report - 34 Changes
Uplink PC
Uplink Report PC
707
6
SatelliteGuys.US DishNetwork Uplink Report - 4/20/2015 09:55 - 34 Changes
Uplink Comparison Range: 4/20/2015 09:48 - 4/20/2015 09:55 (PST)
Channel Removals:
4212(215) - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
4212(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
4353(215) - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
4353(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
4477(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
4751 - WNE [MPEG4 SD] (NA)(H) removed from Echostar16 61.5W TP 03 Conus (WNE)
4751 - WNE [MPEG2 SD] (NA)(H) removed from EchoStar14 119W TP 15 ConUS (WNE)
4752 - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
4752 - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
4947(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
5052(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
5370(215) - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
5370(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
5550(215) - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
5550(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
9602(215) - WNE [MPEG4 HD] (NA)(H) removed from Echostar16 61.5W TP 10 Conus (WNE)
9602(215) - WNE [MPEG4 HD] (NA)(H) removed from EchoStar11 110W TP 22 ConUS (WNE)
9652 - WN [MPEG4 SD] (NA)(H) removed from Echostar16 61.5W TP 03 Conus (WN)
9652 - WN [MPEG2 SD] (NA)(H) removed from EchoStar14 119W TP 15 ConUS (WN)
MAP Changed:
4213 - WN [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS map (215) added (WN)(NA)(H)
4213 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
4352 - WN [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS map (215) added (WN)(NA)(H)
4352 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
4476 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
4946 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
5051 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
5369 - WN [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS map (215) added (WN)(NA)(H)
5369 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
5542 - WN [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS map (215) added (WN)(NA)(H)
5542 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
9653 - WN [MPEG4 HD] Nimiq5 72.7W TP 23 ConUS map (215) added (WN)(NA)(H)
9653 - WN [MPEG4 HD] EchoStar11 110W TP 19 ConUS map (215) added (WN)(NA)(H)
Name Changed:
215 - WNE [MPEG4 SD] Echostar16 61.5W TP 03 Conus renamed to WN (WN)(NA)(H)
215 - WNE [MPEG2 SD] EchoStar14 119W TP 15 ConUS renamed to WN (WN)(NA)(H)
Transponder Changes:
Echostar16 61.5W TP 10 Conus (21.500 8PSK 2/3) removed.
EchoStar11 110W TP 22 ConUS (21.500 8PSK 2/3) removed.
Channels in the system: 9693
(A) = Available to subscribers
(NA) = Not Available
(H) = Hidden from non-subscribers
(FP) = Free Preview
The Format and Layout of the SatelliteGuys Uplink Report is © Copyright 2014 SatelliteGuys.US and may not be republished without written permission from SatelliteGuys.US.
SatelliteGuys Uplink PC Version 1.0.0
© 2014 - All Rights Reserved - SatelliteGuys Incorporated
They moved from one satellite to another. This is all that happened. The way the software looks at this it that it was removed from one satellite and added to another therefore it's listed separately.
I really don't think it means anything that affects us, the consumers in any way.
i was wondering what was going on cmon dish turn the weathernation hd channels and the app for us we would appreciate it very much.
Reactions: lazydogmot
So, if I'm reading you correctly, there's still 2 WN channels?
Looks to me like they are set to add WeatherNation at anytime. We still do not know however if it is postering during negotiations with The Weather Channel or if they intend on adding it either way. There are very few channels DISH does not have that I really care about but this is one that I think would be worth getting. (And yes, in HD)
I think they should
i wish they would add it tonight scott said the rumor was they were going to add it today or maybe we have to wait till wedensday for the uplink report i hope it comes soon enough.
4/20/2015 22:34 - Uplink Report - 4 Changes
4/22/2015 16:12 - Uplink Report - 1 Change
