what receiver and model will pick them up???? will all azbox do it?
thanks again
do they make a card that will get it all?? and do you guys have any recommendation???
thanks everyone
azbox can and dvb card that can do dvb-s2 + proper codecs
nope it wont do 4:2:2Will the SatHawk PVR800 do it all to???
And what would i need to get HD like a 8psk??? Cause i asked a guy about the azbox elite and he said that i needed more to get HD channels not sure i only have SD stuff
When the video opens up on my PC screen, it's starts as a green mask which then gradually "untiles" into the real video, if that makes any sense.
I didn't find any active 13021 4.2.2 feed to check, but I've seen similar behavior to what you describe on one of the AMC3 AP feeds (11726 I think). This isn't 4.2.2, but if I view it with TSREADER, I only get a partial screen in the thumbprint, and the rest is green. If I play it with a STB like the Azbox, it kind of takes a second or two to fill up the entire screen. If I go back to TSREADER, and increase the maximum mpeg picture setting to around 30, THEN I get an entire screen for the thumbprint. This was explained to me over at satforums as being that some feeds only send partial video information with each frame, and it might take a few frames of video before the entire picture is received. With the AP feed, it took 30 frames.I'm not at all sure that different existing firmware version will help. I'm running the latest firmware , and some of the SR 13021 feeds still don't have video. I use a PCI solution for those problem feeds. My suspicion on the 4:2:2 feeds with no video is that a different encoder is being used, or some non standard option.
