4.2.2 PC USB Tuner?
Ranger One
Cheektowaga, NY
Recently purchased an OpenBox S10 which works well though I can't view live 4.2.2 feeds with it. (Unless I'm missing something!)
Is there a PC USB DVB-S2 tuner out there that I could use to view live 4.2.2 video?
I was looking at the Prof AdvanceTune 7700 USB.
Any help would be appreciated!
I would recommend an internal PCI or PCI-e DVB-S2 tuner card. A USB tuner device may give you a lot of stutter on high bitrate feeds (at least it did for me; with an internal card no probems!)
If you are looking for a good solution that directly interfaces with your TV, I suggest purchasing a AZBox which does 4:2:2 natively. I learned the hard way, that this is the easiest solution. Plus, the AZbox does just about everything you would want to, including the ability to stream to a local network. The blind scan is not as good as the Openbox, so I have mine setup as a slave. I use my USB tuner to investigate feeds using tools in Linux.
Let me know if you have any questions.
Chris
how to format usb flash drive for pvr viewsat pro
Another newbie question
