More and more people are reporting programming using 4:2:2 instead of 4:2:0. What do you need to receive it? Do only PC cards receive 4:2:2 and why?
PopcornNMore said:Thank you Iceberg. If only they made a reasonable priced FTA receiver that offered 4:2:0, 4:2:2, AC-3 audio, Digicipher and analog capabilities built-in.
Arion said:For any that are using the PCI cards (I use both PCI card and desktop recievers) for 4.2.2 video you need to use the elecard codacs or you will get a black screen.
CharredPC said:I actually haven't had much luck with Elecard here. It shows a much-too-small squished screen with an annoyinglogo in the top-right corner
I have a few codec packs I install that gives me a few different options that produce 4:2:2. If anyone cares, I'll go look at what codecs I use and links.
CharredPC said:iammike:
Elecard doesn't come with myTheatre.
You probably had some DVD software installed at one point that now automatically works with MT. If you don't have the logo, it's a sure sign you either aren't using Elecard or you have the registered version on your system.
PopcornNMore said:More and more people are reporting programming using 4:2:2 instead of 4:2:0. What do you need to receive it? Do only PC cards receive 4:2:2 and why?
Hehe - silly HD, it'll never catch on.n4bbq said:I wrote PansatUSA and they do not plan to build a 4:2:2 receiver.
derdude said:I use TSReader with my Twinhan card and out of the box the TSReader decodes 4:2:2.
CharredPC said:Wayn23, I use ProgDVB and MyTheatre. Neither has any settings that fix the Elecard squished screensize (that I've found). As Arion said, it gives a weird 3:4 format. If my dish decides to show up today, I might get a chance to see what (free) codecs I use that work fine for 4:2:2.
