I need to keep trying, I've noticed I lose some quality as dish moves east... maybe I need to check the mast, too...
Based on what you said, checking for plumb and true south orientation would be the 1st thing I would do. I get the 30° W bird great on a 39" Primestar.
I did do the inverted mount install after constantly having to dump the water out of the feed throat every time it rained. Being just 11-12 ° above the horizon here the LNB pointed down sufficiently to make a nice lil rain catcher....lol
On my inverted install, I used a horizontal pipe bent down ~45° That was necessary to allow the dish to clear the mounting pipe when being pointed higher in elevation.
Inverted mount obviously means the pipe comes from above instead of below the dish. Without a "kick" in the pipe, the backside of the top lip of the dish will hit a straight vertical pipe before it points high enough in the sky to see the satellite.
You should have no issue with a 30-36" dish, but a 1 meter+ dish will give you some wiggle room for rainfade.
I'm guessing that 6 footer is an offset feed style dish? Did you happen to get the matching LNB/feed/scaler with the it? Proper scaler is everything for proper illumination, aka max captured signal.
You shouldnt need that big guy for Hispasat. You might consider using it to bore site (center) it on a favorite sat near the center of the arc and populating either side of the center point with LNBs set to get some of your other favorite sats from a single fixed position dish.
I cant recall, but I think the guy(s) that were playing with that type of install were getting close to +/- 8 to 9 or so degrees (from the centerpoint) coverage of the arc on a 6 footer with acceptable signal loss at the edges.
If you are interested in such an install, ping Anole, he can give you all the details, including the switchboard from hell diagram. Bandstacked LNBs would go a long way to simplify switching in a full blown setup , but they are pricey by comparison to the garden variety units, plus your receiver(s) must support bandstacked LNBs.
Have fun!
