Should be the same as you did beforeNow I am trying to switch back from "30 Skip" to "30 Slip" and nothing works to switch it back, any suggestions?
I would try doing a reboot of the recvr and when thats done, then try it again.As I said, I have done that several time before on the HR34 and HR44. I was always able to switch it back and forth and the keyword was 30skip & 30slip without any space. Now on the HR54 it worked only with a space between the 30 & skip but it wouldn't switch back to 30 slip with or without the space.
The reason I want to switch back to the 30 slip is as I posted separately, for some reason I lost the horizontal scroll bar on the client when I hit the Advance button (30 skip). I am not sure if it has anything to do with the fact I changed the 30 slip to 30 skip or it it is just a coincident. Tech support has no clue what is happening.
Fwiw, i have that same software on my HR44.Jimbo, I am not a newbie, rebooting was the 1st thing I tried (actually tried it a couple of different times). This is my 3rd 2 year contract with them, I switch every 2 years and I have had all of their Genies by now.
texasbrit, what is your HR54 software version? My HR54-500 software is 0xcb6 Mon 3/6 2:06a. Are you sure you can switch between 30skip and 30slip and your video actually switches between "skipping" and "slipping"?
